- Jan 18, 2010
- Residing in Wicklow Ireland
It’s worse than that, its dead Jim... Sorry...so sadly I think the printer is a write-off.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
From service mode some settings can be changed and the ink absorber counter and some registered data can be resat or deleted. There is no reset procedure that can repair a defective printer.Wasn't there a procedure to re-set the printer, by holding down the two buttons while applying the main power.... would this be worth a try?
Dave
Even you cannot bring the patient back from the dead.It’s worse than that, its dead Jim... Sorry...![]()
Reading the comments (and the replies) I gathered that if the standby voltages are correct, the odds are high that the regular voltages will be correct and the psu is good. That would then point towards the logic board as the culprit.
