- Thread starter
- #31
- Oct 27, 2005
- Location
- South Yorks, UK
- Epson, Canon, HP... A "few"
Hey Mikling, yeah that consideration has been at the forefront of my mind but in this particular instance the black banding appears to be a printhead issue for this particular printhead as it did it immediately with the OEM cartridges installed from new.
The pressure fluctuation from bending/flexing is something I did incorporate into my posts from earlier in the last 24 hours hence the air buffer which should at least attenuate the issue somewhat.
For all that the evidence I've seen in my print-outs indicates the banding issues return is not related directly to the flexing as it's not localised to one or other side of the page, instead it seems to be a starvation or over-pressure issue as I've demonstrated and thought I'd cured in the past.
Further to that it appears that there's levels of this "gradient" banding that are indistinguishable visually.
From what I can tell, the initial gradient banding can come about either due to over-pressure (from which the printhead can recover) or print-head starvation (tubing ID too small, blockage in lines, etc..). IIRC the problems with the printhead I started with a couple of days ago, were actual starvation issues so I'm pretty sure I stressed out the printhead enough to make it feed badly. Time will tell if I can revive it or not but we'll see..
