canonfodder
Websnail,
Thank you for your answer. I remain very interested in getting a successful CIS for the iP4200. I now have a couple of spare iP4200s and will soon have some extra empty cartridges to work with.
I plan to try a system which has the ink feed tube enter the cartridge sponge area through the air vent actual entry point, located just 1 inch forward of the cartridge rear end. I will be working with the ink feed tube going right on down to the bottom, as Grandad35 has suggested. My experiments so far look better when no air can go back up the ink tube toward the bottle, and having the ink tube go to the cartridge bottom provides that. Of course "looking better" in a bench experiment may not prove to be better in a real CIS setup.
I also will be trying a system which keeps the ink level in the bottle at a constant relation to the cartridge bottom elevation. This is to provide a constant zero pressure level at the sponge chamber bottom, as the Canon Pixma cartridge does with its internal "chicken waterer" or Marriotte's Bottle scheme. I am hoping that this approach will prevent problems of air leaks at the exit port seals. Perhaps the ink pumps will be happier too? I think so, but things don't always go as I think. :/
