- Nov 27, 2010
- Location
- Copenhagen Denmark
- Canon MP990
Hi PeterBJ,
Thank you for replying.
I tried your tip but still could not get into service mode
I was able to get into service mode using the instructions described in MG6120 service manual (Turn off printer. Press and hold On button, press Stop 5 times then release Power button). The printer was connected to my laptop with a USB cable; no other printer was connected. I tried many service tool versions: 1074, 3200, 3400... Each time I pressed "EEPROM" in order to get a printout of EEPROM info. Every the service tool version hung after the "EEPROM" command was initiated, no error popped up. Now, the printer refuses to go into service mode. Disconnecting the printer overnight and trying again do not help either. I think it's permanently screwed up.
I searched the web for the MG6120 service manual to look at the instructions for entering service mode, but I only found links to paid downloads. If you have a link to a free download, please post it here, else could you please copy and paste the instructions here?
The reason I'm asking for the service manual or the procedure for entering service mode, is that the procedure for entering service mode in this manual seems different from the procedures in any other Canon service manual I have seen, and I have seen many manuals and performed quite a lot of service mode operations on various Canon printers. I think the manual might be wrong; errors in some Canon service manuals do exist.
It looks to me like the procedure described doesn't have the step one from all other service manuals that I have seen:
1. With the machine power turned off, while pressing the Stop button/sensor, press and hold the ON button. (DO NOT release the buttons.)
2. When the Power LED lights in green, while holding the ON button, release the Stop button. (DO NOT release the ON button.)
3. While holding the ON button, press the Stop button 5 times, and release the ON button. (Each time the Stop button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green.)
4. When the Power LED lights in green, the machine is ready for the service mode operation (nothing is displayed on the LCD).
I suggest you give the procedure above a try. I have a strong suspicion that the procedure from the service manual for the MG6120 is wrong. But this printer also seems to have touch sensors instead of traditional push buttons, so maybe the procedure in the service manual for entering service mode is correct for these printers. Once again, please copy and post the procedure from the MG6120 manual.
Normally if service mode operations are attempted on a printer that is turned on, but has not entered service mode an Error 006 window pops up:
If I open a service tool and no printer is connected to the computer or the printer is not turned on, everything in the service tool window is greyed out, and the program does not respond to clicking any buttons, and no error messages pop up. So is your service tool window greyed out?
Here is the window for the service tool ready, click to enlarge:
And here for the service tool greyed out, click to enlarge:
Maybe something is wrong with your downloaded service tools, you could try to download from the source mentioned in this post by Tudor: http://www.printerknowledge.com/threads/canon-service-tool-v2000.6615/#post-49791 You don't need to download all the service tools, only download the newest version 3400.
My newest printers are the iP3600 and MP540, both of the PGI-x20/CLI-x21 generation and your printer is newer and has sensor fields instead of push buttons, and the service manual seems nowhere to be found. But in the service manual I have for newer printers the procedure for entering the service manual is the same as for the older printers. The only difference is the number the stop button is pressed to enter service mode. For most older printers it is 2 times, and for most newer printers it is 5 times, so you could try the procedure above with both 5 and 2 times pressing the stop sensor.
I wonder if Canon introduced a shut down procedure for entering service mode if a wrong sequence of button pushes is executed too many times, like too many wrong attempts of entering your PIN code at an ATM terminal?
I don't understand this shutting down of service mode entry, did you perform any test prints from service mode, when the printer seemingly was able to enter service mode?
@The Hat could this also have happened to your Pro-1? I wonder if a secret code could then unlock service mode again?
