- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
See PeterBJ's post above. See below for one exception as to cartridge model type (but NOT chip model type).Are cartridge chips color specific?
The best solution is another OEM CLI-42 Yellow cartridge that has been flushed with Windex with Ammonium D as per instructions discussed previously.if I want a spare yellow cartridge ready to go
If you want to swap the chip, then a flushed used Canon OEM CLI-8 Yellow cartridge is the best "compatible", because it is Canon OEM construction, appears to be overtly identical to the CLI-42, and has the yellow plastic identification on the cartridge top. Used OEM Yellow CLI-8 cartridges may be easier to source than a used Yellow CLI-42 cartridge. Otherwise, any properly flushed CLI-42 or CLI-8 cartridge, regardless of color, can be used after the OEM CLI-42 Yellow chip is swapped.
