- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
YES! Plain water may cause Yello Gello, as will Precision Colors refill Yellow. You need to flush the OEM Yellow cartridge first before refilling.Do I have to worry about gelling when the OEM ink mixes with the Precision colors ink in the print head?
Yes.Pharmacist's Solution is a solution concocted by someone named Pharmacist
Forum member Websnail, the owner-operator of Octoinkjet, initially thought his Yellow did not cause Yello Gello but then he reconsidered and added a warning on mixing with OEM CLI-42 Yellow.I had gone with OctoInkjet before because you could mix the yellows with OEM ink
