- Thread starter
- #11
I let the printer set overnight and it started to print correctly.I guess it was an air bubble like you suggested.The only bad thing is the head cleanings i did used up over half the ink in the cartridges.I guess head cleanings uses ink like a horse dranking water.Thanks for all the helpful tips from everyone.I printed some photos on epson premium luster paper and premium glossy and they look outstanding.mikling said:You have an air bubble within the print head.
Been through this too many times. Just installed three CISSes on R800s in a couple of days. You must be patient.
This is the key weakness of the Epson piezo head but it is unavoidable for consumer level printers.
For an immediate solution. Let the printer rest overnight and try again....That's the biggest Epson secret. Three tries then wait a good few hours. If that doesn't fix it, remove the offending cartridge and reinsert it. Why? The Epson cartridge is completely sealed. When you insert it, you pressurize the system a little and the last valve inside the cartridge only opens at the last step of insertion. This small pressurisation can burp the head.
What is happening in a head cleaning is really a head purging that attempts to clear a clog.
The basic technology/principle of clearing the clog is flawed. Hear me out. What you have are 8 sets of nozzles all connected to one suction pad. Let's suppose there is a real clog on one of them. What happens when you apply suction to the set of nozzles? Ink will flow out of the ones with the least resistance and the one with a real clog will not flow ink. So how will the clog be cleared? It will not. Yet it works. So what is happening? Well. 99.5% of the time a so called clog is trapped microbubbles within the printhead piezo pump.
When you have air within the piezo pump, the air is compressible so when the piezo head pump squeezes to pump ink it just squishes air and no ink will shoot out. Hence the so called clog. Just because ink does not come out doesn't mean there is a clog, not necessarily. When you apply a head clean, you basically hope you pull the air out of the head by flushing the ink through the passages.
At the factory the heads are supposed to be filled with some type of liquid that prevents air from getting into the head. Sometimes it is not successful. Understand though that anytime, you remove a cartridge from an Epson you risk getting trapped air inside once you reinsert. The risk is quite small but irritating nonetheless.
That is why my recommendation with good refillable cartridges is to learn to refill them in within the printer. It is easy. That way you don't risk getting air in the head once air has been removed. On the Continuous ink system page, I wrote about temp fluctuations. This is one possible cause of so called head cloggings on CISS, when the temperature drops, the ink is pulled back into the cartridge and then the piezo pump which is just at the end of the line is now filled with air. I remember walking into my first physics class in high school and the teacher taught us "you can't push on a rope" and that was the trick to a lot of physics problems. Well in the world of Epson, you can't pump air with an Epson head. You can only pull it out with a "head cleaning". Liquid is incompressible ( within the confines of a printhead), air is.
If you return the printer, it will go back to Epson, where the techs will test it, flush the head and then sell it at their clearance center for a good price with shipping included. I want an R1800 so please return it and maybe they will drop the price and I'll get it for a song. Please Please. I'm serious.
http://www.epson.com/cgi-bin/Store/BuyEpson/ccProductCategory.jsp?BV_UseBVCookie=yes&oid=-13267
Sometimes they are marked down to $249 for the R1800 when they have too many. Looks like they don't have too many right now as they still are $349. Sometimes the R800 are down to $139 but at that price you can bet they don't last long and get snapped up. Hey since I let you guys in on this, the R1800 will never get that low again. Looks like they sold out their R320s for $179 recently. A printer that was on clearance at stores for $99 three years ago.
When the news of the R1900 gets around, watch the demand for the R1800 go up.
BTW
That is the very reason why Epson left lots of ink inside a cartridge when the chip indicated empty. People got upset and some organization in Europe was also upset, then retracted when they learned of the reason why. It is indeterminate how much ink will be pulled out of each cartridge when the resistance of flow determines the amount. That resistance is not predictable. So Epson uses some guess as to much on average should come out but it can be more or less. Secondly and more important, is that in the event someone runs the cartridge dry until the head is filled with air, and then goes out to buy another cartridge, it may well turn out that over half of the new cartridge may be used before all the air comes out to get a perfect print pattern.
That is the reason why I offer deep vacuum prefilled refillable cartridges to avoid this potential. Many people just put ink into the cartridge and then ask the printer to start doing the prime to suck ink through, then get air into the system resulting in banding and poor print quality, not knowing what they did is fundamentally wrong.
Considerations.
BTW, the choice of a Pro9000 and R1800 are very different printers. The R1800 I would choose for permanent prints or prints that must last. The Pro9000 would be my choice for prints that do not have to last. Otherwise the running costs of the R1800 is going to be higher. No question. But if you need the properties of pigment ink, then there is no other option in that price range.
