- Oct 27, 2005
- Location
- South Yorks, UK
- Epson, Canon, HP... A "few"
Going back to the algae issue, most of the dyes in use have some form of biological source so the inhibitor, biocide (or whatever you want to call it) has to be there to stop the algae having a dye-style lunch at your printers expense.
If you think back a little, the critical bit is going to be, not just the ink but there's all those other factors important to life which include light, heat and air. Most of us know about the exposure to light and keeping things cool (but not frozen) but I wonder how many consider what's in the air. There are plenty of spores around that differ from place to place and if you ever watch a sun beam through your curtains at home, you often see all the dust and other specks wafting around, so it's all out there.
Ultimately the biocide/inhibitor is going to degrade over time and, as Brian noted, you may be introducing contaminants from earlier ink if you suck back into the bottle (something I hadn't thought about before) so there's no such thing as the everlasting ink pot.
That said, having discussed the algae side of things this past few weeks and considering every variable under the sun, moon and stars, it's clear that some practical adjustments could be made to the supply of ink, volume, refill approach (eg: don't suck back) and a few other things.
All in all it sounds like we've all had a bit of food for thought and doubtless will be refining our refill practices some more... Every day's a school day eh?
