- Dec 27, 2014
- Location
- Germany
If you try to print 'gray' as a mix of colors you would have to 'white balance' the output, the ratio of the CMY colors against the color temperature of the ambient light. If you adjust your colors to a neutral - gray - look at daylight it'll look brownish red under lamp light. But to do it this way it may look less irritating since a warmer tone of gray at lamp light at a lower brightness looks less irritating than the greenish cast at daylight at a much higher brightness. So try this - adjust your image to gray - turning color saturation to zero whatever other tools you have in your editor for this purpose and then change the color temperature of your image so that you get a 'gray' looking output at daylight - it may have a strong cast on the screen. Softproofing won't help you much.
There is a reason that you can select different paper types in the driver, it adjusts the output taking some properties of the paper into account which you selected - mainly the black level and the related contrast range, ink saturation limits and such, it's a kind of base line profiling. You can play with these settings to see if it prints better this way or another way.
This is not a problem specific to the L805 but it is a general limitation when trying to mix colors to gray - it just works for one light condition. If you want to print with real gray inks you would have to switch to special inks for this purpose such as the Piezographic inks.
You can try another option available in the driver - the grayscale option - try this - it will most likely use the black ink only if you select normal paper or inkjet paper, not glossy paper; it will dither grayscale tones with the black ink only, the print may look a little bit more coarse than with the standard settings, but be aware - even the black ink is not neutral , and this will become visible at lighter grays, it'll tend to a blueish violet tone - most likely - on glossy paper. So there are several steps you can test to find out which give the best look overall for you.
