Bad nozzle checks
Illusiveimage
EPson Artisan 837
The Nozzle cleaner arrived. I tried forcing it through with syringe, following YouTube instructions, That just made a mess. My printer has stationary cartridges. Apparently the hoses are shut off when not in use. Eventually I dumped out most of the black in in the CISS cartridge module and hooked up a siphon hose from the cleaner bottle. after a couple of cleaning cycles, I got a good nozzle check.
I hooked up the ink line again and it seems to print just fine with the mix of ink and cleaner in the cartridge now. I guess I will just have to flush thru the mixed ink. I'm not going to print anything I need to keep for a few weeks.
I know I have to print regularly to keep the printer functioning properly. I found some instructions for using Windows 7 scheduler to print a file automatically every day. I haven't been able to get it to work in win10. Hasn't someone written an app to do this. I would think it would be simple enough.
yousefwow
epson p50
change your black ink your problem will be solved. your inks are old.
