Westok
Epson L1800
This are patches from Argyll - not exactly for same paper but very similar.
I had a demo version of your software running for a short while, without a spectro, I'm using the i1profiler software, and when I scan a patch sheet with 96 colors I get this after scanning, the scanned colors are displayed, the black patch here is the top left one, I can double click on it and get the actual values as scanned.
The black patch in your 50 color patch sheet is located at the cursor position with RGB=0,0,0
So how does your program/scan screen look directly after scanning - probably somewhat similar to mine ? Can you do a data read out with a double click on any of the color spots on the screeen ?
Westok
Epson L1800
Sorry, now i get it... :)
This is similar patch set for different paper (also matt). Here is print screen... Black is upper right corner...
O.K. - fine, you are reading RGB= 39,37,33 for the black spot, I take an average for the gray value of 36 and devide it by 2.5 and get 14.4, this is the approx L value ( the calculation is not completely correct but good enough for this purpose, RGB ranges from 0-255, L values from 0 - 100 ), and this L=14.4 matches very closely your step wedge reading of L=14.7, there is no fault with the data, not at all.
You are posting 2 profiles with rather different black level in # 358
www.printerknowledge.com/threads/a-basic-guide-see-post-1-to-setting-up-argyll-cms-profiling-on-your-computer.8570/post-122015
These differences in the black level cannot be explained by reading errors, are these profiles for different papers ? I wouldn't know otherwise where such differences could come from, but I'm not familiar with ArgyllCMS and its parameters. And it's these black levels which deliver a good or not so good contrast.
Westok
Epson L1800
Big thanks for your efforts!
In post #358 are profiles for exact same paper taken even from the same box. I am allways getting less contrast profile from argyll...also on glossy papers (ilford smooth pearl), hahnemuhle photorag Baryta... And what i would like to find out is argyll parameter/command error or i1Studio hardware limitation with argyll.
These differences make argyll profiles useless and even printing from driver with epson adobe rgb settings are giving much better looking prints with less accourate colors.
could it be that you are using different driver settings when you print the patch sheets either for i1Studio or ArgyllCMS ?
Westok
Epson L1800
Argyll patches are printed with Adobe Color Printer Utility and i1Studio directly from application. Both is printing with driver, same settings (Photo 1440, unidirectional, same paper type, no color management...).
can you print the patch sheets for both programs stand alone with the same driver settings, not from inside of i1Studio and run the profile then again.
Westok
Epson L1800
I will try that, thank you.
juanmata
Roland VS-640i, Epson T5200
I'm so sorry for highjacking this thread but it was so interesting I thought I would join in. In fact I'm not sorry at all lol.
I'm just getting back into colour management after a few failed attempts over the years and always resulting back to the trusted default profiles.
Anyway I have re-downloaded Argyll CMS and after a few issues I have managed to get a target printed using the following commands:
targen -v -d2 -G -N0.75 -R -e8 -g128 -f1848 test_target
printtarg -v -ii1 -L -a0.84 -b -e -t300 -m3 -M3 -pA4 test_target
I am literally just printing my new targets and I aim to read them using the following command once they are dry:
chartread -v -H -B -T0.4 expert_target
Finally making the profile using this command:
colprof -v -qh -i D65 -o 1931_2 -S AdobeRGB1998.icc -cmt -dpp -DPROFILE_NAME standard_profile
I'll be honest, the last two commands were copied from the internet and the first 2 have been trial and error after having issues with printing and trying to read them. Hopefully my first three commands will be enough to at least get a profile made.
Reading your posts you all seem to have a lot more experience than me when it comes to this so, how do they stack up?
I'll give you a breakdown on how I design:
• I design in Illustrator
• I use Pantone spot colours to design unless I need a specific colour then I use Pantone Colour Bridge
• The reason for using Spot colours is because the colours seem to pop more when using spot colours as apposed to using the bridge swatch
• Use Adobe 1998 colourspace
• Print Using PDF which have been exported using PDF/X1a
• I then use A RIP called Versaworks that drives my Roland Printer
• The colour management settings I use in there are
• Adobe1998
• WideGamutCMYK
• Matching Method
• Raster: Perceptual
• Vector: Colorimetric
• Finally I use Embedded Profile
• and Preserve Primary Colours
Hopefully that will give you an insight into my process.
