5 step guide to Printing cd/dvd Pixma 3000, 4000, 5000 {USA models}
LinkinParkIM14
Houston, Texas
I got my site up and running, all the links should work fine now. http://printers.pokeyoureye.com, on the page you'll find pictures of the cd tray, and 8 short movies on what it does. I guess i overdid it a little, hehehe. Also, i was skimming over < http://www.stevesforums.com/forums/view_topic.php?id=36631&forum_id=40&page=19 > and i saw someone said that it needed to be black all over. Is this true? I noticed that in one of your cd tray pictures that it is black on all of the top part.
Thanks,
Trent
KnightCrawler
Earth
I see some problems:
1. Reflectors don't seem aligned properly
2. The top is to short
3. The tray is to flimsy
4. The top layer is not thick enough
5. The printable cd seems to have a bigger center then standard
LinkinParkIM14
Houston, Texas
Just a little update, color about half of the total length of the cd tray black with a sharpie worked wonders, printed on my first cd. Actually they are labels on cd's because i didn't want to order actual printable CD's before i knew if the printer was going to work correctly or not. Thanks for all your help :)
zakezuke
Righto, these sites have moved so update your links.
CJB had some nasty stuff happening with their popups. There was a report of a trojan "PacerDMedia.Installer" on one of their popups. As a direct result knightcrawler and my self moved our sites.
-----knightcrawlers
http://pixma.webpal.info/ - 5 easy steps
http://pixma.web1000.com/ 5 easy steps
-----zakezuke
http://pixma-faq.periastron.com The more verbose info (mine).
http://pixma-faq.periastron.com.nyud.net:8090/ - e-bay users use this link
-----some other guy
http://pixma.theupgradeguy.biz
Nifty
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
SIDENOTE: zakezuke, let me know if you guys (or anybody else) would like to move your content to my site www.nifty-stuff.com.
I've got a great program that is really easy to use. If your stuff is nifty enough I'll link to if from the front page of the site! :D
zakezuke
If you mean mirror the site I have no objections. I can't speak for knightcrawler but i'll let him know.
panos
Greece
KnightCrawler and Zakezuke, I read some of your postings at Steve's forum and I am VERY impressed! Especially the part about MP7xx's service menu!
BTW, do you guys know any way to reset the waste tank counter on the MP7xx ?
zakezuke
I still need to translate this bloody manual. I know it was kinda translated but the language used in one section isn't the same as in another.
The service mode is clearly indicated as [menu] [scan] [copy] [scan].
Under #7 "printer' there I think is an option to change the value of the waste ink.
Under "test mode" there is also under "#8 etc" sub "#4 ee-prom clear" sub "#1 ink count"
There is also a factory mode if you hit menu while under "test mode"
But i've not had cause to use it so i'm not positive.
