- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
I dont know either ways the rights or wrongs of sealing the hole when using the German methodmrelmo if i went with the wax i think i would more than likely end up pushing the wax into the cartridge
but tape on the top fill method will only end in coloured tears.
The best tape or any tape does not have a strong enough hold on the cartridge to prevent it leaking,
just give it time and the leak will start slowly and before you know it,
theres ink everywhere except in the cartridge that is.
Youll need a complete air tight seal while the cartridge is in the printer (100% not 99%) when using the top fill method
its probably the most common mistake made by would be top fillers everywhere , so please dont include yourself in that statistic.
When using hot wax just squeeze enough onto the cartridge rather than into the refill hole
and then when cold it is easy enough to remove with the edge of a sharp knife.
Just slip the knife under the edge of the wax just a little and lift slightly then the wax will release its grip
and if any wax goes into the reservoir it wont do the ink, cartridge or the printer any harm long term at all.
Happy safe refilling..
