you are addressing several issues above,
- banding , I'm not really clear about this effect, when is it visible, with one color only, in dark or light areas,
with a fixed distance or ???, could you please print and scan a sample showing the effect, and the nozzle check, just that, not a complete page with higher resolution, and a small portion of a print. It might be advisable to get the service manual, I don't know whether there is already a maintenance adjustment program available for this printer, this would tell you whether there are particular adjustments possible. I know there are for other Epson printers. One source could be 2manuals.com, and other sources.
- printer choice, I showed you above that the larger format printers can print with the same effective resolution as desktop printers. But with 4pl printers I definitely would choose a printer using light color inks. If a printer would dither a light cyan tone just with the regular (dark) cyan ink you would see , at close distance, some graininess, same you can see on photo prints with the Epson desktop printers using CMYK Durabrite inks more directed for office type printouts. Those models work with 3 or 4 pl droplets.
- I would not expect much visible difference between the L1800 and D6 inks, their main difference is longevity, stability. against UV and ozone influence for which the D6 inks should perform better. But you need to create profiles for these inks in combination with your papers. I would not give very much on sample printouts for which you don't know how they are created. You may look alternatively for ink cartridges used by the Fujifilm Drylab printers, DL600, DL400,410,430,450,very similar to the Epson Surelab series, there are ongoing offers on Ebay US for pretty steep discounted cartridges like this one
http://www.ebay.com/itm/FujiFilm-DL...ow-Set-of-4-/301449029177?hash=item462fc32639 or more
You may dilute the light colors yourself, that's not a problem , you are making your own profiles to correct any deviations, and you don't pay the full price for an ink diluted by the manufacturer.
- I have seen somewhere, by an American ink distributor, dye inksets offered for Epson large format printers, claiming to have the same colors as the original inks, thus no need for other profiles (as long as you print on Epson papers), and Epson was offering dye inks for the Pro 7600 as well.
One source here
http://inkjetsolution.eu/en_US/c/For-Epson-78009800/39
or just for a black to print films
http://americanscreensupply.com/index.php?l=product_list&c=66
and there are other offers for special sublimation inks which as well are a special type of dye ink, the dye with the sublimation properties, and there are more.
