- Jan 18, 2010
- Residing in Wicklow Ireland
I was one of those who maintained that continued deep cleaning could damage a vulnerable print head when it has obvious signs of clogged nozzles because of the stress that it can cause leading to overheating.
I strongly suggested limiting the deep cleans to just two and if that doesn’t visibly work then removal of the print head is necessary for better cleaning outside the printer by overnight soaking. (But be sure it’s not the carts first)
Every time you run a cleaning cycle that counts as a print cycle because the heads have to fire to push ink through the nozzles, so the less you do the longer the print head will last, not to mention your ink and where it all goes..
