Epatcola
- Mar 21, 2020
- various
An ET-8550 arrived, is filled with 105/106/114 ink, and now I need to create some profiles. So back to the question I had with the ET-7750 - what media type for what paper?
There are 4 non-matt media types available in the driver
Ultra Glossy
Premium Glossy
Premium Semigloss
Glossy
The installed profiles for these types are as far as I can tell are identical which makes me question if choosing one or another makes any difference to the printing process.
I profiled some cheap glossy paper using each of these media settings. I set quality to high for all but Ultra Glossy which I profiled with high and best settings.
The 4 high quality profiles look very similar. The Ultra Glossy best profile was different showing a bit more volume, more linear mid range, and darker black. The best setting takes around 50% longer to print. I wonder if that best setting uses some BK ink to help with blacks the same as the VFA media setting does.
I think I am of the opinion that for non-matt papers there is no point profiling or using anything other than Ultra Glossy media type with best and maybe also high quality settings.
I guess for matt papers I will profile with Matt and VFA media settings and see which looks best.
I note that ET-8550 profiles from Fotospeed only use Premium Semigloss and Archival Matt (I assume that is VFA equivalent) media settings. Profiles from Permajet and RR seem to use media settings vaguely matching the paper type.
Does anyone know more on this subject?
Ultra Glossy
Premium Glossy
Premium Semigloss
Glossy
