Epson stylus photo1400 won't stop initializing
Northrim
Epson Stylus photo 1400
I've got an Epson stylus photo1400. I don't use it often. When I tried to start it up recently it won't stop initializing. By initializing I mean the print head moves back and forth and it sounds like it's charging the heads. Even after several hours it's still going. I've tried starting it up with and without the PC connected, with and without the ink cartridges installed. I've unplugged it and plugged it back in several times. Tried cleaning the heads. Nothing works. Any suggestions???
bplaman
Epson Stylus Photo 1500W
Hi!
In order to determine the malfunction of the printer, you need to know the error code.
For this, download the "Printhelp" or "Epson Printer Connection Checker" program.
Install on your PC and see the error code.
Northrim
The printer is showing up in device manager but Epson connect Printer setup can't find the printer.
bplaman
Look at which indicators and how they blink when the printer is turned on. This way you can determine the error.
I am attaching 3 files of pages from the Epson 1400 Service Manual.
bplaman
Post here a video of the LEDs blinking while your printer is running.
Northrim
I am attaching 3 files of pages from the Epson 1400 Service Manual.View attachment 15732View attachment 15733View attachment 15734
Thanks;
Only the power button blinks. .5 sec on, .5 sec off repeat endlessly while the printer head moves back and forth. I've let it go on for hours before turning it off so this is not just normal charging of inkheads. Occasionally it will stop for about 1 second then resume.
bplaman
Do this:
Do not forget to open the trays and insert a sheet of paper
Northrim
Do this:
I followed the instructions in the video: It did not help.
Prinhelp.exe seems to be able to find the Epson 1400 but since I don't speak Ukrainian I have no idea if it is giving me any additional information on the printer.
bplaman
Set the Printhelp language to English.
Watch the video below.
After changing the language, close the program and run it again.
  • PrintHelpEn.zip
