Canon PRO 300 5B00 error
cosmingheorghe
Canon PRO 300
Hello! I have a canon PRO 300 that displays error 5B00. I contacted a service, and the people there told me that there was nothing more I could do. Can I still solve this problem? Thank you!
cosmingheorghe
Canon PRO 300
This is the documented Canon response to the 5B00 error if you are out of warranty
https://support.usa.canon.com/kb/index?page=content&id=ART179094
You probably can find inofficial resetters like this one
https://www.impresorastotal.com/reseteo/resetear-impresora-canon-imageprograf-pro-300/
(Use Google translate if needed)
But such resetter won't replace the waste ink pads/storage elements
I used the reset program and it worked perfectly. Thank you very much!
The second link suggest downloading a service tool.
This is how to reset the ink counter, but take care about the version number.
Only versions dated after the release of the PRO-300 are susceptible to work.
Others will block all further access.
FYI: this is (an evaluation copy of) version 5103 from 2018
The version for the PRO-10 already had number ST5204, I wouldn't dare.
You will have to pay a few bucks for a reliable hack.
Search on eBay, I've seen version 6000 (no guarantee but much more chance).
Do your research, good luck and report back.
PS: the ink absorbers will not overflow the next day, this is something to tackle later.
websnail
South Yorks, UK
Epson, Canon, HP... A "few"
Going to ask the question... Has anyone actually pulled a Pro300 apart to work out how to change the pads or fit an external waste ink tank?
Alternatively has anyone done the same on a Pro200? Asking as I may have the opportunity to do just that but I'd rather follow in someone elses footsteps if at all possible as I suspect I'll end up wrecking a unit if I don't have some clues in advance.
Similarly access to a service manual while unlikely would be very welcome, if anyone knows of a source.
This seems to be an unexplored territory. AFAIK none of the regulars here owns these printers, so you'd have to be a pioneer and endure the foreseable mistakes... :rolleyes:
Have you searched on Youtube ?
As for a service manual, PeterBJ is the expert, but I suspect that the only place to look for it is Canon's vaults
