- Jan 18, 2010
- Residing in Wicklow Ireland
Print Head Explanation: -
HB-A:... PM, PBK, MBK, PC, GY... HB-B:.. M, Y, C, G, R... O’ you may Grey and GO instead of R and G.
The alarm bells ring, this then panics a lot of Canon users, over this 60-hour cleaning cycle thing, but what it comes down to is nothing, I would like to put this whole Feckin nonsense to bed for once and for all.
Firstly, YES, your printer will do a cleaning cycle after 60 hours of non-use, that is fact, BUT it will also do a cleaning cycle each time you use the printer before the mythical 60 hours’ time has arrived anyway, so what’s the problem.
The amount of ink that the printer will use for cleaning on start up after 60 hours has lapsed has also been overly exaggerated, it uses no more that it normally uses on a regular cleaning cycle, so panic over.
Here it is in English:- Quote “ If 60 to 120 hours have elapsed since the previous cleaning cycle, till the start of the next printing, then the printer uses 1.4 ml on the (H B- A side) and 1.8 ml on the H B- B side)” If the time lapse is 480 hours then the amounts doubles.
When an ink tank is replaced, the printer will use approx. 2 ml of ink, but that can vary wildly, like: PC or GY.. 1.9 ml, PBK or MBK.. 2.2 ml, PM..2.5 ml, M or Y.. 2.1 ml, C or G.. 2.4 ml, R.. 2.8 ml.
Wait there’s more: - When You Frig around with your print head by trying to clean it externally the printer will use 8.8 ml, and that’s not the end of it either, any power outage will result in an instant cleaning cycle.
There is one further action that cause a big cleaning cycle to occur, if the print head was not capped when you powered on the printer it will do a huge clean cycle, a whopping 8.8 ml is used, so don’t clean the purge unit to often...
BUT, if you power off your printer with the button provided, or allow it into sleep mode, (Same thing) the printer can still remember the last time it did a clean cycle, so it won’t automatically clean on start-up, but it may clean before it starts to print anyway.
Putting the printer to sleep or leaving the printer powered on 24/7, achieves exactly the same thing, except one uses far more electricity, but pulling the plug from the power socket every night will cause an automatic clean cycle on start-up, Ouch 4.7 ml...
All ink usage is measured in Grams, and 1 Gram of ink is equal to 1 ml of ink, and the amounts quoted are for each individual cartridge...
Because this information was taken from a Canon Pro 9500, you can dismiss the amounts of ink used for cleaning purposes, unless you have a 9500 yourself, this printer was used as a prototype (Or guinea pig) and all other pigment and dye ink printer will use approx. half of the stated amount above, phew...
Foot note: if you do anything out of the ordinary with your printer, then expect it to run a cleaning cycle and the newer model are worse for that, for instance, cancelling the ink monitoring will cause excessive amount of cleaning, this will double the ink wastage...
The only sure way of getting back at your printer is to change all your cartridges together when one become low, that’s a huge saving over 12 months...
P.S. Isn’t it Just Grand that we can use 3rd party inks, it saves my sanity anyway...
E&OE..
E&OE..
