PalaDolphin
- Jul 25, 2016
- Saint Paul, MN
- Canon Pro-100, HP 7760, RX500
Two questions:
1. Did I overfill my cartridges?
2. What is the best way to adjust for Precision Colors' ink being a bit darker?
I just ran out of the original Canon ink from my new Pro-100 and went to swap out all the carts with the ones I refilled with PC ink. I really didn't think I would need gloves.
When I tried to remove the clip from the first one, magenta, I definitely squeezed the sides too much and ink came out of the venting hole. But, even when I was more careful, ink still came out the bottom. Luckily, it wasn't too uncontrollable. I was more worried about the printer having a problem. After I installed all eight carts the printer reported full ink and it printed without an issue. Is this because I overfilled the carts?
Second, the PC ink seems to print a little darker. I printed this Bald Eagle, title: Unanticipated Launch.
I've been using Lr to print. I am using the PC ICM D50 file for this paper, Canon Luster. And I used the same everything from the last print that caused the ink out except, of course, the PC ICM. So, I could use Lr's Brightness control; I don't know how much I should add. It goes from -100 to +100, but how does that translate to stops? And it doesn't have a preview; that is, when you adjust Brightness, it doesn't reflect on the display.
I would much prefer to have a better solution, like adjusting the ICM file. But, I don't know how to do that.
