iml
- Nov 3, 2014
- canon ip5000
I’ ve been refilling cartridges with ARC chips bought from octoinkjet for a year with no problems. Nothing that couldn’t be solved with a cleaning circle from time to time at least.
Two months back I had problems with the pigment black at the nozzle checks that persisted and needed 2-3 cleaning circles each time to solve.
I took measures and primed the cartridge once again (no visible residues at the bottom of the sponge), did an extra cleaning cycle (perfect nozzle check) and continued monitoring with nozzle checks before printing something. Any clogs where dealt with normal cleaning cycles (PGBK only) thinking that at this rate the waste-ink pads will be filled.
15 days back -after the last 1/3 black missing nozzle check- I decided I had to start using canon cartridges sooner, now that a resetter for 550-551 cartridges is available. I ordered a set of used cartridges to be flushed and a resetter, left the printer aside for 15 days expecting to start new.
Now, 3 normal and 1 deep cleaning cycle later, the nozzle check is worse than ever. The pigment black is very faint and almost missing from the nozzle check. Of course I haven’t tried to print anything other than nozzle checks.
Dont mind the colors, its a bad scan (default canon settings), however it is exactly how the pigment black (1st row) looks.
Both the “original” ARC cartridge and the canon octonk-refilled cartridge give the same nozzle check.
I opened the -until now unused- setup PGBk cartridge that came with the printer only to take exactly the same nozzle check.
Any suggestions on how to safely solve the (should be) black pigment clog?
P.S.
I am reluctant to remove the printer-head for windex-kind of cleaning since the one and only time I did, it was a complete disaster. Maybe the solution used wasn’t friendly enough (windex alternative for EU and Greece specifique?) or the printhead wasn’t completely dry inside and sorted, a sad story…
P.S.
