Urgent help Canon ip4920
oroblec
Dominican Republic
Canon pro-10 - Epson L1800
i just had tried to clean the printer head with warn water and i dried it very well with not luck maybe now is time for wyndex on printer head.
oroblec
Dominican Republic
Yesterday after cleaning for some hours the pad with alcohol I left it alone turned on and wait to make a nozzle check and this is the result one of the best of the last couples month so what do u think problem are in the purge system or I need to soak the print hear or just continue soaking the pad but this time with wonder.
oroblec
Dominican Republic
Sorry happy 2014 and thanks for all your answer and tried me to get this done thanks and I wish the best for all you.
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
Your pgbk nozzles are working. I appears that the residual cleaner on the purge pad supplies a small amount of fluid to the nozzles. It could be either the pgbk channel in the printhead is bllocked (blow air through the black inlet port and see if it comes out/bubbles out the black nozzles), or the purge syslem for pigment black is not functioning.
The potential causes for a non-functioning purge unit range from blockage in the vacuuming system ( which requires a lot of patience to unblock, or considerable disassembly to clean), to a disconnected hose in the system (again, requiring disassembly to re-connect). I have had solid blockages in purge systems that required using fine wires as tools to dislodge the blockage in fine passageways in purge pump manifolds. I have had tubes come loose INSIDE the vacuum pump, and also tubes come loose connecting the purge pad to the vacuum pump.
The vacuum pump used by Canon is a peristaltic-type pump.
Test the purge system for operation.
1. Apply cleaning fluid to the purge pads with an eyedropper with the print head in the cartidge change position. You must be able to build up a standing pool of fluid on the pads that stays. If the fluid disappears from the purge pad over a minute or two, that indicates a leak in the purge system that must be found and corrected.
2. If the standing pool of fluid persists as expected, then close the printer cover and let the printer go through a cleaning cycle. Re-open the printer and visually inspect the parking pad. ALL TRACES of standing fluid should have disappeared. If not, then the purge system is not functioning (most likely clogged).
3. Inspect the black rubber gasket around the parking pad(s) for distortion. This gasket seals against the print head nozzle plate so vacuum can be established. If it is distorted, the ceramic insert may have been disturbed. Typically there are at least four rubber "tabs" that lap over the ceramic pad that must be positioned correctly to the gasket has the correct shape. The gasket can be "nudged" with a fine wooden tool if needed.
Wayne
Thank you very much for the purge unit test instructions. :thumbsup
  • Like
Reactions: Ant
oroblec
Dominican Republic
can i use alchol for this test or just wyndex ?
turbguy
Laramie, Wyoming
Alcohol is much more volatile than ORIGINAL FORMULA Windex. I would not use alcohol. You can use clean water for the test (preferably distilled).
oroblec
Dominican Republic
i have distilled water i will start the test in a few minutes i will post picture and results of the test.
oroblec
Dominican Republic
test done 3 minutes with the destiled water and make a pool on the black pad and no leak with the cartridges replaced position so i closed the cover and he made the purge and when i check again the pad were empty what is next ?
oroblec
Dominican Republic
It could be either the pgbk channel in the printhead is bllocked (blow air through the black inlet port and see if it comes out/bubbles out the black nozzles) how i do that with one syringer ?
