- Dec 27, 2014
- Location
- Germany
- L805, WF2010, ET8550
I found a way to 'edit' a data file which contains scanned color data, I have edited this in a text file with the theoretical color values of the patch sheet which let me compare this data with another data set from another scan , I had to convert the 96 colors of the patch sheet from RGB to Lab data, There are several RGB to Lab converters available on the internet like this one which can deal with 11 different color spaces - scroll down
http://colormine.org/color-converter
I was testing again against these numbers gray step ranges with pretty disappointing results - grays are not gray but pretty colorful, that's easy to see in the scan results when the Lab a and b color values differ very much from 0 . I need to check for the influence of the rendering intents, and there is more to investigate
