- Thread starter
- #21
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
It seems an SSD really can speed up things. Could the need to re-migrate be caused by the SSD not being the C drive? But I'm no expert on these matters, so I think you should wait for comments before re-assigning drive letters, else you might end up having a system that will no longer boot or no longer have access to stored files.
?That's an impressive improvement.It seems an SSD really can speed up things. Could the need to re-migrate be caused by the SSD not being the C drive? But I'm no expert on these matters, so I think you should wait for comments before re-assigning drive letters, else you might end up having a system that will no longer boot or no longer have access to stored files.
How do I write "C colon backslash" without "colon backslash" turning into this smiley?
Interesting background Andrew, I think we are in a field of emerging technology. From the blurb SSDs do suffer from failures and each supplier is evolving system software to counteract and protect from the effects.
In my case, Samsung provides two packages "Samsung Magician" and "Data Migration". As far as I can gather they run the SSD in parallel with a hard disk C drive which continues to hold its own copy of all the software. The SSD operates at high speed on its own copies of the programs and data files, producing very fast results.
It also has a process which evens out the stress wear on the SSD by redistributing "use" over the entire memory area.
So if you have a failure you don't loose much data, only the work in hand. Just replace the SSD and re-migrate the files from C drive.
Cheers,
Google is your friend. Unless you are working on a notebook or some other device in which you want to conserve battery power, then set your computer to never go to sleep. Instructions at http://www.pcworld.com/article/256309/tweeking_windows_7s_sleeping_habits.html.I have noticed that when C goes to sleep (after 10min) any externals connected shut down and also have the message G system reserved! To get it active again I have to reboot which is a pain in the... ( someone out there will have a fix I am sure)
I think that would be "distributing". Trim or garbage collection is what allows the freeing up of previously deleted files to be wiped from that space thereby enabling data to once again be written to that space.It also has a process which evens out the stress wear on the SSD by redistributing "use" over the entire memory area.
