- Dec 27, 2014
- Location
- Germany
You are listing a Canon G5070 with your personal data, is this still correct ? This Megatank printer uses 4 inks - black pigment and CMY dye inks, it might be difficult to extract the inks from the tanks to swap them, it is pretty important that no air gets into the tubing. You may need to wait with the ink swapping until the colors run empty. A CIS printer in my understanding is a cartridge type printer with a CISS retrofit by the user, after installation. There are as well quite some larger printers with cartridges which don't move but feed the ink via tubes as well , models which I wouldn't call a CIS printer - sorry for the misundertanding that you use a Megatank printer and call it a CIS printer.
Printers with this 4- ink configuration have a limitation - with the black ink, the pigment ink is only used for the normal and matte/inkjet paper setting, and not for photo printing on glossy paper, the black parts of an image are mixed with the CMY inks which is not really black but pretty dark with a color cast - mostly violet. And it could be that the pigment ink is not used as well on normal or matte paper if boderless printing is activated - I don't know if that's available on this Megatank printer model, and the pigment black is not used by Canon printers if full duplex is available and selected. Could this black issue be one of your print quality concerns ?
There is a work around on Epson 4-color printers that you use a dye black ink instead and just print with the matte paper setting on glossy paper to activate the use of the black ink channel. Epson does not block that when printing borderless.
