I am not sure the OP's problem is caused by using a wrong profile. It would not be just the color of the shade that would be wrong. The skin tone would likely be way off too if a wrong profile is used. The OP is using a 3rd party ink. This could be the reason of minor color issue.RogerB said:It's true of course that every ink set has limitations in its gamut, but using the wrong profile, as the OP is doing, often fails to achieve the maximum gamut of the ink set. Using the wrong profile will definitely alter the rendering of in-gamut colours, whicih is the real problem here.
I think everyone is likely to always make some adjustment to every image to be printed. There may be a desire to crop the image a little for example. There may be a desire to adjust the contrast, or adjust the overall density or very often color balance. The camera's auto color balance never really do the job right. The OP's problem could be just an easy step in an image editor to adjust.RogerB said:The problem with this approach is that you will have to "adjust" virtually every image depending on the image content.
14 a profile may be not too bad. But I have 8 - 10 different paper I use. That would be 8 - 10 profiles to purchase. If you are really serious about rendering accurate colors I agree that you may want to purchase a profile tool (big money). Still you will encounter the issue of gamut limitation of the ink/paper. I would not take this expensive and difficult route to address minor color balance problem caused by the camera.RogerB said:The colour balance of third-party inks differs in subtle ways from that of OEM inks for which the generic profiles were made. Non-linearity is almost impossible to adjust out using trial and error. Most people in this situation find that profiling solves the problem more cheaply than constant adjusting. You don't say where you are located, but in the UK for example you can get a good custom profile for 14. Is that too expensive when you consider the frustration you are suffering now? It's a one-off cost that you offset against the savings that you are making on ink.
We really don't know what the OP's real problem is. Since he is going to try some profiles. Maybe we will hear the result from him soon.
