BruceW77
- Jul 5, 2018
- Melbourne, Australia
- Canon/Pixma Pro-100S, Pro9000
Avalanche, the fact that the “action, movement” you notice occurs “before a print" is a good sign that the activity is a cleaning cycle. The duration of a cleaning cycle is typically 60s and uses a bit more than 0.22ml per cartridge (on average) or a total of 1.8ml across all 8 carts. As others have pointed out you cannot stop these cleaning actions, but it is very useful to understand them, particularly if you use OEM ink, where you want to minimise waste ink.
There is a very simple test you can perform to confirm the activity is a cleaning cycle. Next time you observe the activity, take note of the time and date. Every time you print for the next 5 days check that the activity does not precede the print. After 119 hours and 45 min (that’s 15 min short of 5 days) send a nozzle test to the printer. Half an hour later send another nozzle test to the printer. If you have not removed any ink cartridges or had a power failure during the 5 days then the only time you should get the cleaning activity (before a print) will be with the last nozzle test and not with the one half an hour earlier.
With the Pro 100, cleaning cycles are controlled by a 120 hour timer, which is started following the last cleaning cycle. Expiry of the timer results in the next cleaning cycle with the first print that follows the timer expiry. There is also a longer timer which will result in a larger purge of ink (double) if the printer is not used for a long time (20 days). A manual clean will reset the timers. There is no 60 hour timer on a Pro 100.
There are other times you will hear activity, movement, typically after a print. These activities tend to use significantly less ink.
