- Dec 27, 2014
- Germany
- L805, WF2010, ET8550, T3100X
Epson has Ecotank printers running much longer than Canon, the print mechanisms are the same as they used in the comparable expression home or workforce models, or the photo printers P50-L805 or 1500W-L1800, Canon apparently uses somewhat different hardware, but problem reports about printheads are not very frequent yet in other print forums. You may check with Epson/Canon whether they offer a warranty extension to 3 years if you register directly after purchase - such options vary by model/manufacturer and your country - and the time of the year - with special deals etc
You cannot count the lifetime of a printhead by time - 2 years or whatever is not relevant , nor by the number of pages printed - photo or text prints would make a big difference in ink coverage - it all relates the the total amount of inks pumped through the nozzles.
The is def. one benefit with all of the these models - no hazzles with refill , cartridge compatibility , cleaning cycles related to cartridge changes, resetter etc; although every piece of printer hardware does some cleaning cycles nevertheless as it is programmed into the firmware. - timed or after connection to the mains, after long print jobs cleaning off the nozzle plate etc - and the inks are priced much lower than in cartridges
