jackson
I think Defcon is right and Canon is not.Wam7 said:I printed a sheet of black text using the 'Photo Paper Pro' setting and the text was printed in perfect black. Hmm, any recommendations on what printer I should get next. :/
If the 'N' block is supposed to be photo black (according to Canon) then something is telling the printhead to use Yellow and Cyan in error.
But it sure looks like it's supposed to be a composite of CYM which means the magenta is missing.
I printed a yellow block then overlayed part with cyan.The result is the same as your image.
So I conclude that some magenta nozzles are blocked..just as Defcon alluded to.
Here is a partial extended nozzle check of a Canon i850 with a bad head.
It prints poorly set for plain paper, but is quite acceptable on plain paper if the setting is changed to 'Photo'.
Taking the Magenta as the good nozzle, compare to the whole section missing from the cyan.
