Water killed my print head
BrightGuy
spikey said:
I recently got an old IP4500 printer. When I first used it with fresh compatible cartridges it produced a perfect nozzle check print.
As the print head was very dirty with old dried ink and also wanted to switch ink type so I flushed the head with hot water first on the head side followed by the inlet. I did this until no ink appeared from it and it looked clean. I left it for a day for it to dry before refitting it.
With the nozzle print, now I get streaks across the cyan and magenta colour bands :(. No matter what I do, like leaving it soaking it in Pharmacist solution or using the same solution in ink cartridges.
I hope I haven't damaged the print head as I read many guides on using tap water to clean it.
Can't afford a new print head costing 60+. Please help?
I have success with not dilluted Windex. I fill a shallow saucer until I reach a column of 1 or 1.5 mm above the bottom of printerhead. Leave it for 60 minutes, while droping around 1cc of Windex through ink inlet. Then reinstall it into the printer and do 2 or 3 cleaning cycles. Do it preventively every 2 or 3 months. Printerhead remains like new. I use OCP inks.
Grandexp
stratman said:
I am a little surprised you didn't suggest 10 ml Ammonia to 1 liter water. You were the one I mentioned in my post above having success with that formula most recently.
Sorry, I did not read your whole post. I agree that it was probably a tip appeared on this forum before.
spikey
That sounds like a good routine to keep the printer in good shape. I don't print many pages so chances of clogging would be quite high.
After soaking in Windex, do you rinse off the Windex and dry the head before reinstall into printer.
spikey
One thing that has puzzled me, from the nozzle test, all the colours have streaks but only the pigment black remains perfect. Is it because the nozzles are larger or what?
Grandexp
They are still clogged a little for the same reason. Don't push them to print too soon. Two days of soaking should help. I would only allow them print anything only the streaking becomes hard to see. I would print lightly initially and make sure the streaking does not get worse. It will clear up eventually. I won't print photos until maybe a day or two later visualizing that it does not get worse.
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
Yes, the color nozzles ARE smaller than the pigment black nozzles.
You might want to try a short (1/2 hour) soak in warm white vinegar to dissolve any potential mineral deposits remaining in the nozzles, followed by a distilled water rinse. Do this at your own risk, however....
Wayne
rodbam
Australia
Canon Pro 9000 mk2 & Pro 9500
I know you don't want to waste paper but it makes it difficult to see the prints with the colours coming through from the back. Why don't you do your nozzel checks on one side only & then you can use them in the toilet to save wastage:)
I've heard Aussies are tough but copy paper for latrine duty is asking too much to believe.
Have you been peeing on electric fences again? :D
Agree about the nozzle check, though.
spikey
The 2 days of soaking turned into 6. Unfortunately had to go away for a few days. At least it had plenty of time the clean any clogs, but it seems it has not made any difference. :(
These are the latest nozzle output:-
I can't understand how rinsing in warm water has ruined a good print head. Is mineral deposit still the most likely cause, and if so is there something more potent solution to get rid of this.
What solution were you using to soak? How were you soaking the print head?
Did you try the vinegar solution turbguy suggested to rid hard water deposits?
Is the nozzle check NO different after all the soaking?
Do I detect a checkerboard pattern in the small color squares as well as the tow long horizontal stripes in the second image, or is this artifact from compressing to a JPG and/or posting on the forum?
