Vintage HP/GretagMacbeth Eye-one Pro spectrophotometer: still sealed
I could finally could hold of imatch 3.6.2 that can be downloaded and did work with my i1Pro1. The nicest thing was the ability to use the scanner profiling using the included target chart that must be scanned with the i1Pro1 spectro and saved and scanned with the scanner and based on both readings a scanner profile is generated, which to my eyes is very accurate.
I have found a 3D model that does a better job than the one from HP: now I have to find somebody who can print it for me :oops:
  • ruler basem EFI ES 1000 230x60x3hmm hole 6x210x4hmm & 9x246x4hmm.stl
mavtop
Epson XP 15000
This is mine :)
If you want to fix the hole, use that of the little one ruler (you have the link to download it) it has a bigger hole.
the problem with the ruler is that can be used for horizontal scanning, if you want to use it for vertical scanning, you need to make it longer and you need a 3D printer that can print A4 size models
my printer can't print A4 size models so i had to adapt it for horizontal scanning (A4 is 210mm x 297mm), so i used the 230mm to have space on the left and right side to go over the white spaces at the begin/end of the rows scanned.
if you want pharmacist i can try to adjust that hole for you, but before to that you could try the little one version, bigger hole but it is a little flexible i have to adjust it, so it is more stable and durable.
