palombian
- Feb 4, 2014
- Location
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
Adding something to PeterBJ, in x20/x21 ink type printers and newer, using one on more of following options forces CLI-BK instead of PGBK:
- auto duplex printing
- borderless printing
- photo printing (see media type mentioned by PeterBJ)
- cd printing
Also some quirks in Windows can force CLI-BK instead of PGBK, no matter of other options enabled.
Ł.
P.S.
Dried/clogged nozzles in CLI-BK printhead (narrow black ink tank) are by far most common reason for dreaded errors: U052 (1403), B200 and 5200.
Continuing on this, the absolute low cost way for Giancarlo could be:
- only print from the rear tray (no duplex)
- select grayscale printing
- disable cartridge empty warnings (at own risk)
- buy a bottle of black pigment ink (and a syringe) to refill the PGBK cartridge (and avoid it to run empty)
- fill the 4 CMYK CLI cartridges with a neutral liquid (pharmacist solution or even distilled water, same as above)
Another solution could be to tape off the contacts of the nozzles fed by the 4 CLI cartridges on the printhead, avoiding the refilling.
A complete refill starter set (resetter, drill, syringes + 600ml ink) costs only €50-60 for about 10 refills, after that only ink has to be purchased.
