- Dec 27, 2014
- Location
- Germany
Both the matte and the photo pigment inks print through the same nozzles or nozzles with the same droplet size so you can assume that the pigments have a somewhat similar size. Photo pigment inks are advertised as encapsulated which create the glossy look and may provide better adherence to the paper surface/coating. Matte inks are not encapsulated . I'm not aware of serious tests which prove that matte inks cause more nozzle problems than other inks - hearsay statements are missing in most cases additional information like the type of printer used - the ink brand or the printing habits of the user. It may very well be in particular cases but I doubt that the ink is causing the effects in all cases.
Let me clarify the operation of the cartridge chips and the resetter, there are two types of chips on the market - one which you can reset with a separate resetter at (about) any time. You trigger the driver to let the printer move the carriage into the exchange position, you take out the cartridge(s), refill them and do a reset which sets the counter back to the full status, this allows you to fill up several cartridges at the same time with variying ink levels.
And there are ARC chips - Auto Reset Chips - which report as well the ink level - that's not a function of the chip but the driver /firmware counting droplets and their size, and the firmware writes the actual levels to the chip. The ink level drops during printing to the point that the cartridge reports empty/not available . You take out the cartridge, refill it and reinsert it into the carriage and the ink level status jumps to full again.
You can take out and refill such cartridge at any time in between at any ink level but you cannot cause a reset this way , the firmware acting together with the chip data does not let you to get a reset this way, the printer firmware remembers the last ink level data before you take out the cartridge.
K3 inks on matte paper , I don't hink there is really much you can see in an image of such print, it's more what you can measure - the black level you can acheive. The black level on matte papers is typically not as low on matte papers as on glossy papers with the resp. inks, but it's as always - it depends - on the paper and the brand of the ink.
You can measure the luminance of the black level of various inks on various papers and you'll find that ink 1 delivers the best black on paper 2 , but ink 3 a better black on paper 1.
I made some measurements with the Conecolor 'blackest black' ink - as claimed - it's not always the blackest black.
https://www.printerknowledge.com/threads/matte-inks-for-epson-printers.14396/#post-126861
