canonfodder
I'll start this out with my startling report concerning last night's operation. It has become a FNO post. Sorry
I have been refilling CLI-8 color carts in my Canon iP4200 for a while now. In their turn, each cart was declared as empty and I did the "continue printing" command with the reset button. The ink monitor has shown those color carts as empty, of course. The little graphic of the ink tank has been showing "no ink" in each of the carts.
I had not printed a lot of text since getting this printer, so the pigment black had not been refilled as yet. It has been saying "ink low" for a while now, and finally it declared that cart empty, making me do the reset to continue printing. With this last cart, the pigment black, being declared empty, last night I stopped other tasks and prepared the cart for refilling, drilling and tapping a hole on top near the front to use for refilling and to take the 6-32 screw with "O" ring for sealing.
I filled the prepared cart, installed the screw, let it drip, (which it didn't do much at all) and returned it to the printer. Knowing I would be away from the printer for a little extra time while drilling, tapping, and filling, when I removed the cart, I had closed the cover to let the print head be parked in its normal parking spot. I thought this might reduce any drying. (Even though there is a humidifier out in the hallway, our house is so dry you could shake out your washed wet shorts three times and they'd be ready to wear!) So when the cart was prepared and flled and sealed, I returned to the printer, and opened the lid. The print head dutifully came out, and I reinstalled the pigment ink cart and closed the lid.
Nothing unusual yet? Yes, but wait!
I decided that a printing a nozzle check print would be a good idea, so I brought up the maintenance page and selected the check print. When the printer got ready, the "all carts empty" ink monitor presentation was the UNUSUAL thing.
THE PHOTO BLACK CART IS SHOWING FULL !
THE PIGMENT BLACK CART SHOWS EMPTY.
ALL THREE COLOR CARTS SHOW HALF FULL !
Almost not believing my eyes, after the nozzle check print finished in fine condition, I immediately printed a full page photo on plain paper. No problem with the print, and the ink monitor still showed the levels as stated above.
I turned the printer off, waited a bit, and turned it back on. I repeated the act of printing a full page photo on plain paper, (as low cost as Kirkland paper is, I just can't bring myself to use it if not necessary). Everything still the same. Print is O.K. and the ink monitor STILL says that the photo black is full, the pigment black is empty, the yellow, magenta, and cyan carts show half full.
Needless to say, I planned to watch that ink monitor closely. Will it report the proper reduction as ink is used? Can I get the printer to do this trick again?
So this morning I had to try a print to see what changes, if any, occurred overnight with the printer Off. I was almost disappointed to find that those half full carts are back to the empty presentation on the ink monitor. But the previously shown as empty photo black cart, which showed as full last night, now shows half full. This then is still an "unusual thing".
One thing I thought of was the fact that I had rinsed off the refilled pigment black cart. Do you suppose that a water droplet trapped behind the chip could have confused the monitor function? I gave the cart a quick rinse this morning to see what would happen, but that changed nothing. Of course, just where would a water droplet need to be, to foul up the action? A water droplet would only conduct a small current, especially at the low voltages present at the chip. A nice experiment would be to bring out a tiny wire from each terminal on the chip and externally try some high resistance like 100KOhms across each combination of the wires. Then again, this phenomenon may have nothing to do with a water droplet or film at the chip. And it certainly has not been proven to reset any chip. At this point, I could only say that the ink monitor reported the wrong things for a while. But I will still wonder "What's up with the photo black?"
What are your theories? What are your experiences, related or unrelated? What have your heard, even from a friend of a friend?
canonfodder the puzzled
