Unclogging Canon Printheads
I would just warn against applying positive pressure into the print head. You can develop hundreds of positive psi with a syringe which can easily damadge it. You are limited to the negative pressure of -14.7 psi which probably won't damage your print head
gigigogu
In my case the vessel is one half of a travel soap case.
Fully agree, only negative pressure (suction), never positive pressure.
Nice. :)
Hi gigigogu
Nice idea. No paper fibres in contact with the print head. :)
What do you use for cleaning solution? Window cleaner with ammonia, pharmacist's mixture or something different?
gigigogu
As I cannot find in my area propylene-glycol, glycerin and ammonia, I am limited to a mixture of 75% distilled water and 25% isopropanol (isopropyl alcohol), used warm, at about 50 C (122 F) to 60 C (140 F).
Thank you for info.
Maybe the key ingredient is patience. It may be much more important than the actual mixture used.
Some have also used sprinkler fluid for cars. It is a water/alcohol mixture with some detergent added. IIRC it has been used with success.
Why dont you use standard washing up-liquid in your mix? :)
Nifty
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
This is interesting...
In my search for "Propylene Glycol" I read that the pink RV anifreeze contains this it and water. I found this MSDS for PRESTONE RV ANTIFREEZE:
http://www.shamrockchicago.com/MSDSPrestRVAf.html
SECTION 2: PRODUCT COMPONENTS
HAZARDOUS COMPONENTS CAS# PERCENT EXPOSURE LIMITS
Propylene Glycol 57-55-6 20-40 None Established
NON-HAZARDOUS INGREDIENTS >1%
Water 7732-18-5
Unless I'm reading that wrong: Propylene Glycol & Water ?
Nifty
Administrator
Bay Area CA
Hey FYI: we've added this great thread to our featured items on the Homepage!
The problem with revising such an old thread is that the links in most of these old posts don’t work with the new system…:hu
