Trigger 37
- Dec 23, 2006
Inkoholic,.... I am posting below a picture of the Service Test print for the MP530. The MP610 is virtually the same but I don't happen to have a good copy. The Service Manual for the MP610 has and example. I have photo enhanced the colors on this image to make them more visible, otherwise the Photo Magenta would barely be visible because it is only 1 pico liter nozzles. If you can copy the image to your PC then you can enlarge the image and see it much closer. Each tiny lines that are printed in "ONE" nozzle firing for about 1/4". While the next line appears at the same location it is actually the next lower nozzle firing. The pattern appears jagged because the first group is printed moving right to left and the next group prints moving left to right. The pattern is continued unit all nozzles have printed. The Green pattern is a combination of yellow and Magenta and Cyan, since they long ago discovered that yellow is very hard to see. As you look at the Black matrix you will see sections that are completely missing. These are clogged nozzles. While it is possible to have a "Burnt out Nozzle", the probability is VERY low, since typically when a nozzles is burnt out the head overheats and the temperature sensor in the head goes way up and the logic card generates an error and shuts the head off for good. These nozzles are so tiny, if they get a clog and it is not taken care of right away, it will continue to clog more and more until finally one day the nozzles burns up. Since the logic card has no knowledge of the clog it continues to try and print. The extra ink that surrounds the nozzle is there to "Keep the nozzle" cool. When that ink dries up and makes a clog it "Can not keep the nozzle Cool". The logic card again has no knowledge of this and as you continue to print whatever you want this will eventually burn out the head.
Proper care of the printhead requires that you print a nozzle test print at least once a week, and print something everyday if you can. The instant you see a problem in the test you should do a cleaning cycle to get rid of the clog. You may even need to print a Service Test Print to confirm just how bad the clog is. If it is really bad then you should remove the head and clean it in the laundry room sink using hot water only. Anyone that wants more information on how to do this correctly,...just send me a note and I will respond.
Once you understand how and why things happen to a printhead you will ALSO UNDERSTAND WHY CANON HAS GONE TO SO MUCH TROUBLE IN THEIR DESIGN TO KEEP THE HEAD CLEAN AND TO PREVENT ANYONE FROM PRINTING IF THE INK IS LOW OR GETTING LOW.
