- Thread starter
- #11
Because I couldn't print with my previous sets of chip cartridges since they are not able to recognized anymore and I had to buy new original cartridges, to print out the EEPROM. Which is how I could print out the the EEPROM from with the replacement board and compare them with my EEPROM data from my old logic board. Yes these EEPROM provides activities associated with the printhead and ink usage.Tin Ho said:I thought you said your cartridges are no longer recognized. How could you print the EEPROM data still? Even you could the EEPROM data printed is from the EEPROM in the print head. It records activities associated with the print head.
I just did a refill of a PGI5 ink cartridge of a 3 months new ip4300. It should have the latest revision of firmware in it. The LED of the PGI5 is dimmed and refilling was completed without any problems.
As to the ink issue on that thread and why you never heard from it since is I couldn't do more test because I did it half way and I had other problem that I need to resolve before continuing with the test and until I have more test I couldn't update that thread. I usually do more test before drawing conclusion which is why my testing usually take quite sometime. It can takes months before I finally feel that I can feedback on the result and my test. I hope you try to be a little understanding that I need time to resolve one problem before I can proceed to resolves another problem.
I guessed you were right that I had a lot of problems that others from this forum do not have. So I guessed lin is the problem here.
