The Twilight Zone unfortunately its real..
Grandexp
websnail said:
my guess is that The Hat was indicating that other models waste more ink when using non-OEM ink.
Hum... I think this is wrong too. Waste more ink? Do you mean more than 5 ml? I guess not. Waste more ink when using non-OEM ink?
Sorry, I am in a bad mood. I am picking words from the HAT and your posts.
Seriously, there is no more waste of ink regardless the ink is OEM or non OEM. If a cartridge is not correctly and fully refilled it will run
out of ink sooner. It is a false impression more ink is wasted when using non OEM ink, meaning when you refill.
rodbam
Australia
Canon Pro 9000 mk2 & Pro 9500
It's not a question of wasting ink if using aftermarket inks, the point is if it wastes more ink with the ink monitoring disabled.
Emulator
Canon Pro9000 II
One thing about this site, if you register two separate email addresses, you could have a cracking good argument with yourself!:)
rodbam
Australia
No you can't:)
OK this is an update on my alcoholic Pro1 printer.
Unless I can get third party chips (ARC or one time) this printer is not fit for purpose in its present condition.
Its really a shame because it is such a nice printer and pretty economical to use as well when it functions with full ink monitoring.
The two previous times I used it I lost another 8.5 ml of ink on the unmonitored tanks while the rest of the tanks (Monitored) hardly used any.
When I brought this problem up in my first thread, I was slammed for it and was even accused of lying which didnt surprise me at all because the guy probably failed to read the thread properly (just speculation on my part).
A while back I also had an i9950 running on a CISS which had no ink monitoring and the waste pads over filled very quickly on that printer and it didnt report anything on the waste pads condition either.
That led me to suspect that this is something that goes unreported because theres no way of measuring the amount of ink that is dumped when using a CISS with eight cartridges.
Yes I know it is easy to run a service print to check the normal waste pad levels
but how do you check the unreported levels after the over dumping?
I would therefore recommend the use of some sort of ARC or one time chip to reduce the amount waste of ink building up inside your printer, it is normally not a problem in most Canon printers but you never know..
Grandexp said:
You blew it this time, Hat. Congratulations. Seriously, you don't know all Canon printers. The real difference, I mean one difference I know,
is the detector that detects empty cartridges, is turned off. That is evil by Canon.
I ran out of ink before refilling from time to time. The detector never tried to stop me from printing. But, no, my print head wasn't
destroyed. Not once but 10 times maybe more. I am talking about ip4200, ip4300 and ip4500, not crappy Pro 1 with a self-destruction feature.
You blew it on this one too. Twice in one post. Thanks a lot, man.
Grandexp:
I just read your post that had been flagged and unavailable until now to read.
First, it has long been the gestalt of the forum that post-IP4500 model printers without ink monitoring perform more maintenance cycles of one sort or another. This means more ink gets drained from cartridges than when ink monitoring is once again, or always has been, functional. Some report ink purging continued at an accelerated rate even if ink monitoring had been restored after it had been overridden previously. Those comments by numerous forum members negate your declaration that The Hat was "totally false".
Second, the Hat did not identify printers of the IP4500 design or earlier models in his post, nor did he state that all printers will waste 5 ml's of ink when ink monitoring is off. This was a strawman argument on your part for dubious reasons. While there may be a difference in how Canon handled overridden ink level monitoring previously, it appears post-IP4500 models are different in the view of numerous forum members.
Third, I use a chip resetter with CLI-8 and PGI-5 cartridges and have never run out of ink before ink monitoring has informed of an empty cartridge. It appears you either underfill your cartridges, or, you do not reset your chips and fail to manually visualize cartridge ink levels as is necessary when the printer's ink level monitoring is off. This is a failure on your part to refill or monitor properly based on the capability of your printer.
Fourth, The Hat was offering an opinion, not a statement of fact, about "most Canon printers". He didn't "blow" anything. On the contrary, he restated widely held beliefs on the forum and added objective data concerning the extent of ink purging with the Pro1.
If you are to be judged by what you have written then you blow, grandexp. You have offered zero proof that all printers do not waste more ink when ink level monitoring is disabled, you offered a strawman argument in place of proof, and, you have been insulting where none had been given previously in the thread. You disagree - fine - but leave your attacks out when none were given to you or anyone for that matter.
Grandexp
stratman said:
Grandexp:
Had been flagged? Why? I thought the Hat needed some entertainment. He made an inappropriate generalization of Canon printers. The Pro 1 according to his description is apparently very different from all other Canon printers I have used in terms of how much ink is wasted by the cleaning cycles on starting up to print. My printers do not waste 5 ml. I used my printers without resetter for several years. I also have had a resetter for at least 2 years. I do not notice any difference in terms of ink waste. I have refilled each of my printers at least 100 times. No way I could miss the behavior of the cleaning cycles of the printers.
Not all post ip4500 behave like that. My IP4700 and MP480 behave dot differenly with or withour using a resetter.
Get a printer and use it yourself. You will see how untrue it is. In fact I suspect that my IP4700 and MP480 don't always run a cleaning cycle when powering up. They most of the time don't do a cleaning cycle before printing either with or without resetter. They will do it only when the printer has been powered off for many days or weeks. If the printers were used yesterday they won't run cleaning cycles on powering up nor on starting a print job.
How do you interpret this words he said:
I have discovered that my printer a Pro 1 and quite possible most Canon printers act the same
when the ink monitoring is deliberately disabled by the user or when using a CISS with no ARC chips.
You misread my post. I was talking about without resetting the chips. If the chips are not reset you can run out of ink and the print head will print black without getting any warning. This has happened to me many times. It is a proof that the detector that detects emptiness of the cartridge is disabled. Now let's see what Hat said:
So if anyone of you guy want to save your hard earned $$ then use some sort of chip that will record your ink status on screen
just as long as the printer is not running blind and trying to kill your print head out of pure revenge..
My print heads were never killed by not resetting my chips. I merely have to refill and go. I know there may be a risk but it has never damaged anything. I have an observation about this. If there is no ink (running out of ink) there is nothing for the print head heaters to burn to clog. So my print heads were never clogged. Since I always discover quickly that ink has run out the heaters were never hot enough to destroy anything.
Unfortunately I did not see it that way. It's not just an opinion. It is much stronger than an opinion. Doyou suggest that I should keep quiet and let untrue speculation to spread freely? My post was not just my opinion. I was stating the truth. You don't have to believe it.
You have a point here. I should say quite a few printers I used over the years do not show a difference in terms of ink wasted between with and without using a resetter. But Hat did not point out any other printer that actually proves to waste ink differently.
If Hat weighted his cartridges I can tell you by taking out the cartridges to weigh his printer will do a cleaning cycle after the cartridges are reinstalled. That's probably why his printer wasted a lot of ink. Whenever a chipped cartridge is removed and reinstalled the printer will detect it. The printer will then invoke a cleaning cycle to get the air, introduced when the cartridge was removed, out of the ink passage. The Hat's entire post was flawed if he weighed the cartridge to check how much ink was wasted as he described.
