jackson
That's it.pharmacist said:Strangely enough purchasing a gun in the USA is easier than buying some relatively harmless sharp needles.....
From now on I'm using the Dirty Harry method on those damn carts.
You know, I never actually thought about it from that point of view...pharmacist said:I do take them from my own shop. I think it an advantage to be at the source. Strangely enough purchasing a gun in the USA is easier than buying some relatively harmless sharp needles.....
Unfortunately that approach isn't what the sharp needles are used for... The Durchstich "German" method of refilling requires a sharp needle intially to make the small hole required for refilling so it is relevant.chobo2 said:Can't you not just buy Syringes that are not needle pointed? That would probably solve many of your problems. I know when you got to the stores in Canada and buy a kit the needle that comes with it is round. So you can't use it to stick yourself with but since your just using it to poke a sponge with it a needle without a tip should be able to do it no problem.
As I stated in my post, the issue is Liberty, which we appear to agree upon.pharmacist said:Stratman,
My comment about about those syringes is the freedom to purchase sharp needles without any limitations by us -refillers- in comparison to the USA policies to have everyone the right to bear firearms. I did not say anything about whether these stat laws ar good or bad, but to put everything in comparison that the prohibition of selling or buying long sharp needles is just ludicrous. If you can buy guns, then let people buy long sharp needles if they want. Sounds like reasonable, not ?
