HI,
I just bought a used MP830, described as having a poor magenta channel.
My olde iP5200 died recently, and I have loads of inks left, plus a chip resetter, a spare working head, and a new unused print head, so it made sense to find a machine that could use these. Given the vintage, new is no longer an option, hence I found an MPO830, described as in good condition, other than afailed magenta, using cheap inks. With previous generous advice from here (GHWellsSnr), I;ve learned about print head cleaning and pourge unit unbloicking, so decided to have a go.
However the MP830 seems to have more problems than just the magenta that the advert described...
To start with, on power-up, the LCD screen displays what I presume is an error message in Japanese (I think!?!), and all command buttons generate a warning tone, and no other action. The menus do not scroll (even in Japanese). A yellow lamp (empty ink tank warning) is illuminated on the main panel.
I have tried a system reset as found on various webpages- Link below), but this does not work.
Thinking the problem with the LCD may be linked to a faulty print head or empty ink tanks, I tried to change haed and/or inks, leading to..
Problem No.2- the print head will not move to the central access position when the front cover is hinged down.
Does anybody have any ideas (apart from the obvious one - i.e. that I should have tried it before buying it!)
Thanks,
Jon
Links to hidden 'reset' code:
http://www.wasteink.co.uk/change-language-mp830/
http://printeresetter.blogspot.com/2010/02/how-to-reset-canon-mp800-mp820-mp810.html
Thanks,
Jon
