- Jan 18, 2010
- Residing in Wicklow Ireland
Ill go with Toms Tank Tube too..
I will have to disagree with you on this one George, but only regarding the top fill method.ghwellsjr
If this is used on cartridges that were refilled with the German method, I predict that you will get a lot of ink dispelling from the refill hole as fluctuations in the normal daily atmospheric air pressure forces air in and out of the refill hole. Even if you cover it with tape, as opposed to sealing it securely like is required with a top fill hole, it will still alow air flow in and out everyday. Even if it doesn't result in any ink loss, it will cause a gradual drying out of the ink in the cartridge.
Tom ... not meaning to "beat up on you" at all ... but ...Tom Hock said:and never had any leakage
