- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
I have not used any of the tintealarm.de products that I am aware of. I have read that they sell some well regarded products, though, such as KMP (some have said they have one of the best Pigment Black inks available), Jettec, and InkTec.jopereira said:IS ink would offer me more confidence as many forum members use them, but I'll take the chance with tintenalarm.de also getting positive feedback here (namely stratman).
Druckerchannel has reviewed all the ink manufacturers for one Canon printer or another. Since I can't recall what their reviews said for all these inks, and Nifty-Stuff posters mostly seem to use IS or Hobbycolors inks, it might be a good idea to search for the reviews on Druckerchannel of the inks available on tintealarm.de.
I posted the link to tintealarm.de because you were looking for alternate sources of ink closer to where you live to save on shipping costs. Others had already supplied you with octoink.co.uk as a source for inks, which sells IS and KMP inks for your printer, plus "SquEasyFill Kits" and all the other things you will need for refilling happiness.
I use IS inks. I would not be adverse to trying any of the other inks listed in this post. One poster here, ghwellsjr, is not a fan of Inktec's pigment black ink. He believes it is prone to clogging print heads. (No mention of problems with Inktec's dye-based inks) A search on his name and that ink will eventually lead you to his testing on pigment black inks that may or may not help in your decision.
I understand this may be a bit confusing and overwhelming, but it can be simplified. If you are unsure about the best ink for you, buy a small quantity to try it out. If you are not thrilled with the choice, then you are not stuck with hundreds of milliliters of it.
Because I already use IS inks, I would purchase from Octoink if I wanted a European source. (I live in the USA and purchase my IS inks from Precision Colors on eBay out of Canada) If I needed all the components to start refilling, I would consider their refill kit which has everything you need to refill via the Durchstich German Method - inks, SqueasyFill bottles, needles, and chip resetter. I might ask if they would substitute KMP Pigment Black ink for the IS brand because I've heard good things about it, but it isn't a necessity since IS Pigment Black works well for me. If you are not going to use the Durchstitch Method for refilling, you will need something to plug the top hole you drill for the traditional top fill method. Octoink can help with this as well. While some prefer the traditional top hole refilling method, the Durchstitch Method is my choice.
Whatever you choose, I think you will be satisfied in the end with the savings and the fun in doing the job yourself.
*Disclosure - I have no financial relationship with any mentioned in this post. Octoink is run by Websnail and Precision Colors is run by Mikling - both are posters here on Nifty-Stuff.
