- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
Just thought I'd share a couple of random troubleshooting problems I hit today when an iP5200 decided to hit problems with its paper feed and I then started creating a few new problems.
1. Error 6502 (Ink tank position sensor error)
This will probably happen if you have the printer open (ie: the top removed) and a light shining into the unit. Happened with mine after I dismantled and part rebuilt it. Put cover back on and it worked fine until I shone a light in while it powered itself up and went through the routine and then it balked again.. So lesson: no lights!
2. Judder as printhead passes a specific spot.. No obstruction but the printer leaves blank spots in printout in a line down page.. Weirdly it's slightly different position for each ink output.
Check the little plastic strip that the head uses as a position measure (it's on springs and runs at the back of the printhead near the top). Mine had some grease on it so a little careful cleaning solved that problem and it started printing perfectly again.
3. Ink pool near right of printer after disassembly and reassembly of printer from base.
Yep.. the waste ink nozzle hasn't slotted back into the gap in the sponges and is probably directing ink against the circuit board and off into the far right of the case where it leaks out the bottom of your printer. Solution, take apart again and make sure you get the waste tube aligned right.
There's a few others but I can't remember what there were... hopefully will save some poor sod from the same problem later though
