Shot a new video on Refilling Epson OEM carts.
Callum
I was given an old epson Stylus photo 1270. I've replaced the old cartridges which did a few printings before running out of ink with a projet pj-et009. It is quite different to the t009 carts you are refilling in the video. any leads for refilling this?
Since I do not have any T009 cart on hand, I am not sure.
Take a look on the underside to see if they have the two circular taped over vents.
If they do, then you can, using the valves from Rjettek.
I used to own a Stylus 870 way back and I used to refill directly through each exit port using a plain tipped syringe.
Later on Epson incorporated one way exit ports so refilling that way became an immpossibility.
The 7 pin universal Epson resetter will reset the T009
I just looked on the Rjettek site and it appears that the T009 is indeed refillable using this method.
http://www.rjettek.com/Inkjet-Supplies/Epson-Replacement-Valve-Plugs-20pk.html
Your cart # is listed.
