stuckinthe70s
- Nov 26, 2017
- Epson 2200, Epson 3800
Hi all, this is my first posting here and I have a cleaning question. I recently acquired a 3800 from Craigslist, the seller stated that the printer had been working then suddenly it was printing weird colors. He thought it was clogged but had no success with cleaning cycles or changing a few carts, and stated he was tired of f-ing with it. I gave him $100 and brought it home, along with some extra ink.
Once home I quickly concluded that it was very clogged and I don’t think it had been used in some time. Half of the channels didn’t print at all and the ones that did print were about 50%. Short story, through repeated Windex soaked towel under the print head treatments and cleaning cycles, I now have the printer showing 100% on all channels except the 2 magentas- regular magenta is missing 12 lines on the nozzle check and light mag is missing 8. Additional cleaning has no effect, and the clogged nozzles are always the same.
So the question is regarding the Pharmacist solution- if I were to put some in refillable carts on the 2 magenta channels, is it safe to use the ammonia recipe and leave in the printer for a day or 2, or should I stay away from the ammonia inside the print head? My thought would be to use 2 refill carts with solution, run a power clean followed by some purge sheets and then let it sit to work on the stubborn clogs. Thoughts on this?
Thanks for any info.
