I've filled other HP inkjet cartridges b4 BUT.....this time I'm really stumped!
I have an HP 845c inkjet printer that takes no. 15 & 17 cartridges.The colour one fills from the top & the black has a ball bearing plug that is located underneath.I've followed the refilling inst exactly.The blk states that I must fill it until overflowing then squeeze any excess air out & insert a grub screw in the hole where the ball bearing was.It seemed obvious that it would leak thru the thread so I dripped a bit of hot wax on it to seal it(which I read on other forums afterwards is what usually happens). I also filled the colour cartridges as per inst.Both leaked onto some pad as they should.The cartridges seem to be taking turns on working when I operate the cleaning utility.One works then the other doesnt.If I put them on a pad they flow fairly easily. What the?
