mikling,.... I have to strongly disagree with your conclusion. It only misleads other people. Electrical circuits like the ones that control the firing of ink jet nozzles in Canon printers do not gradually die or fade away, and they don't come back to life after a little rest. They also don't cause banding. They either work or they are bad. Sometimes electrical circuits can become intermitent, but even then their symptoms are either totally on or off,.. nothing in between.
Print nozzles that cause banding can be only one of 4 things,... 1. Clogged individual nozzles,.. that is some are clogged and some are not and some may be partially. 2. Starved printhead due to poor ink flow of ink Carts. 3. Air blockage somewhere in the flow of ink. 4. Clogged or damaged Purge unit that can not suck sufficient ink all the way from the ink tank through the printhead and down to the nozzles. 5. Oh yes, I forgot to mention,... a small combination of all of the above working together such that you see banding. You fix anyone of these and you wil see temporary improvement in the printing. If you never really fix the problem,...history will repeat itself.
If you printed the Service Test page (not the nozzle check) you can see each and every nozzle in the printhead fire for a specific period at a precise place. Every ink drop on that page tells you the complete story about your printer. If you have banding,.. it isn't hit or miss,.. it will be a specific set of nozzles that don't produce an ink DOT where and when they should. A lot of people over look the purge unit but I think it is much more important. If you have any kind of air gap between the ink tank, the printhead, and the nozzles, the action of firing a single nozzle will not work. The resistor in the nozzle heat up ink and creates a bubble which expands until it is ejected. In the process of squirting out it creates a small vacuum which sucks more in through the entire path. Imagine if there is an air gap somewhere in the path. There will be no vacuum to pull the ink along. This is why the Purge unit is necessary to suck the ink out of the entire path to "PRIME" each nozzle so it will fire. Imagine if one, two or ten random nozzles are blocked. They may fire a little but without sufficient ink they can't create the necesary vacuum to pull any ink through the head from the ink tanks. It always comes down to "STARVATION"
Do me a favor and print out from the Service Mode the Service Test data and tell me how many nozzles are not printing in each of the crosshatch patterns for all 6 colors. I use a 10X magnifier to check each one of mine. That is what it takes, especially for the photo Cyan and photo majenta. Also, since there is a second row of heads that Canon uses to print "Micro ink drops", these print in picoliter sizes and you can imagine how easy it is to clog up those rows. Do a simple water flush ink your sink until there is no more ink coming out, then turn the printhead over and let the water hit the bottom of the nozzles full force. Repeat this several times. If you want to you can soak the printhead over night and repeat the process in the morning. The dry the printhead with an air compress or blow dryer. Before you put the printhead back in the printer, check the purge unit by adding some windex or water with a syringe to the black and color ink suction Caps and cycle the printer on and off and verify that the purge unit can suck the caps dry. Verify you ink carts will flow ink out the bottom by blowing in the top of the ink cart while holding it over a paper towel. Install the printhead and run 2 or more Deep cleaning cycles and turn the printer off. Then use the Resume button and the power button to go into Service Mode. Once you get there, press the Resume once then the power button and it will print the Service Test Data sheet. If it is not satisfactory, you can do another deep cleaning cycle in Service Mode and then re-print the Service Test pattern.
I have a Canon iP6600D and the nozzle check pattern prints out 10 rows of color test dots. One for Black and Yellow each, and two each for C,M,Pc,Pm. If only one out of the 3200 nozzles does not work, there will be some banding somewhere. You can get banding if several of the resistors in the printhead actual burn out. Yes they are dead of old age but the Service test data also gives you the temperature of the printhead as well as the ambient temp. The only problem with this test data is that it does not tell you where the problem is,.. it just shows you what is wrong.
