Harry Briels
- Aug 10, 2014
- Mechelen Belgium
- EPSON Pro 3880 & Canon MX925
Is the rubber tip on the syringe, key in filling a Epson OEM 3800 cart?
I have studied with great interest the excellent videos regarding refilling OEM 3800 carts which Joe Rodriguez (jtoolman) did present on this Forum.
The interesting technique Joe developed doesn't look complicated, until reaching the refilling process itself.
I think that there could be a practical problem in the filling process?
Joe uses a syringe without a needle, but with a black rubber tip on it, that seems to fit precisely in the filling opening and which makes it possible while pushing ink into the Mylar bag, to exert enough pressure for doing so.
Because the rubber tip closes off the opening no ink can flow our of the filling opening.
Whether thereby the rubber tip or the exerted pressure do push open the plunger to let ink in, I can not know.
It is likely that when using a syringe with a needle, that the needle must first push open the plunger, which is kind of a delicate operation.
In addition when using a needle ink can not be pushed with a minimum pressure in the Mylar bag because it will then flow out of the filling opening.
The key element in all of this could well be this little black rubber tip on the syringe? So far I have not found this rubber tip anywhere on Internet.
The question is "how to fill without the rubber tip"?
