- Nov 27, 2010
- Location
- Copenhagen Denmark
- Canon MP990
You didn't tell what kind of cartridges you bought. But if they are Canon OEM's and you are using standard plugs to seal a top fill hole, there might be a clearance issue. See this thread: http://www.nifty-stuff.com/forum/viewtopic.php?id=6695 So before drilling any holes its better to check the clearance.
If a plug causes the print head carriage to jam this could strip some gears and ruin the printer. It could also pull a plug from the fill hole causing the cartridge to empty itself through the print head causing cross contamination and a mess inside the printer.
Instead of cutting into your printer as mentioned in the thread you could try to locate some low profile plugs without lips as mentioned by websnail in the last post.
An alternative refill method, that does not use plugs is the"German Method" Here you find excellent instructions by pharmacist : http://www.nifty-stuff.com/forum/viewtopic.php?id=4315
