Red River Review of the PRO-100
Good things ..refilling related.
The new term "setup tanks" scare is now gone. Looks like full ink tanks are included. All hardware related things that worked on the CLI-8 will likely be reusable.
The continued use of what looks to be the CLI-8 body with clear walls. Great!!!!
Resetter will likely have to be new.
Grandad35
North of Boston, USA
Canon i9900 (plus 5 spares)
This photo only shows 8 sets of nozzles - this head is different than the 10 nozzle set head used in Canon's other 8 color printers. I also don't see the heat sink used on the 10 nozzle set head.
Grandad
Good observation. The printhead that I have for the Pro9000, not a MKII is identically the same for the i9900. Can anyone with a Pro9000MKII printhead comment on whether their head looks like this one?
Grandad, when you dissected the 9900 head, you were able to see the internals to see the internals. Was the 10 set actually all used or were two redundant? Also, there was a new part number for the Pro9000 MKII head. Could this be the new part number that we stumbled into fairly recently.
The heatsink was also part of the printheads on the BCI-6 6 tank series. Perhaps the newer electronics has been shrunk and actually uses less current and thus no longer needs a heatsink.
Grandad35
Even though the MKII print head has a different number, I have seen claims that it is interchangeable with the MKI (and i9900, etc.).
The internals appeared to be identical, but the last 2 ink supply holes were blinded off at the joint between the ceramic plate and the plastic body.
rodbam
Australia
Canon Pro 9000 mk2 & Pro 9500
Here's my newish Pro 9000 Mk2 print head I demolished the original one.
Below my 2 year old printhead that I took apart to fix as per Stratmans instructions:)
Next time I will ask The Hat how to take apart a printhead:)
Those are some purty photos, rod. What did you shoot them with?
Great job!
rodbam
Australia
It's a Canon 7D with the EFs 60mm macro lens, thanks mate:)
